Water valve replacement for toilet
Anyone know where to order a water valve? The toilet is a Thetford (2015 T@B).  model number of toilet is 31646. On-line seems to have other model numbers. any input appreciated. Manufacturer is also having difficulty finding this part. photos might help
Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
    Call nüCamp, they will have the parts or can get them quickly. Some parts have a two year parts warranty on them.  Search for a thread by me about a part that needed to be replaced last fall 2016.
    luvmytabluvmytab Member Posts: 66
    thanks Verna, I did call nucamp and spoke to Elsie and she and a fellow worker did not have a clue even though I had the model number and name. I sent her the photos and hopefully tomorrow morn we will get the part ordered. I will check the warranty as you suggest.
    Marvin was the one who knew what was wrong and he knew which part was needed. He now works in Warranty, but maybe Elsie can talk to him.
    edited June 2017
    I bought one for ours on Amazon. Ours is a 2014 (late 2013)
    Cheap, $20. Easy replacement. (Honest, Verna!  =)  )
    Here's the link:
    https://www.amazon.com/Thetford-31705-Aqua-Magic-Toilet-Assembly/dp/B002UC1AYQ
    thank you, chanw! got it ordered and arriving Friday. BTW, i love your little tabl do ya.
    and thank you for your info, verna!
    ok, part is in. the mobile RV repairman charged me $150 to pull the toilet and identify the problem as the water valve.(he also helped up a bit(10-15 min) with the winterizing  Anyone install this themselves? My son has installed toilets in my home and his. Would love any input, before i call back the mobile guy.
    Mr_Mrs_GnomeMr_Mrs_Gnome Member Posts: 241
    @luvmytab, where did you find the model number? I just got my 2017 Outback out of storage and the black fitting popped off when I turned on the pump.
    @ChanW, did you pull the toilet to replace or have it done?
    edited April 2018
    Thanks Barbara
    @luvmytab, yes I installed it. It was a breeze. The (rubber) seal for the toilet to the black tank was included in the 'kit', so no worries about cleaning up wax.
    @Mr_Mrs_Gnome, isn't the above link to the Amazon part correct anymore? here:
    @ChanW, the link is fine. I was just wondering how to pull/reinstall the commode and identify if I have the same model as Barbara.
    dragonsdoflydragonsdofly Member Posts: 1,926
    @Mr_Mrs_Gnome, DH pulled our toilet and replaced our valve last year, June,  2017. He says very good directions are included with the valve. The toilet reinstall is only  2 bolts. The commode is seated on a foam gasket, not wax like in the home. Said foam gasket comes with the valve replacement so you will be good to go. Tip: someone with long arms makes it easier!
    Thanks @dragonsdofly! Sadly I’m 5’3”. Gnomies don’t have very long arms. I might be able to borrow an elf, though!
    edited April 2018
    @Mr_Mrs_Gnome, then you probably have the manueverability advantage in the lieu my DH at 6', 220 lbs didn't. But all in all, sounds like you have a plan!
    What both @Mr_Mrs_Gnome lack in height they more than compensate for in charm.  =)
    Great write-up, Fergie.
    FergieFergie Member Posts: 143
