Yes it does. I was wondering about that. Will check and report back. How much of a difference did it make on yours Jenn.
Jeannie
To be honest, I have never paid attention. I will try to remember to measure before hooking up next time. I do know that it is always perfectly level when I am hooked up, which makes for a nice smooth towing experience!
I have found that setting the ball height on the TV about 1" higher than the top of the coupler ( measured when the trailer is parked level before hooking to the tv) is usually pretty good. ie top of trailer coupler is 18" high from groundbset hitch nall to 19", hook up trailer and see if its level. Usually pretty close,
BigGrover 2019 T@b 400 Boondock Lite 2018 Ram 1500 Quad Cab Hemi Central Alabama
We have a 2017 JGC Trailhawk and use an 8" drop. It looks level while parked. From what I've read Park Mode is the lowest position and is 1.5" lower than Normal Ride Height (NRH) and Aero Mode (highway speed) is 0.5" lower than NRH. So however it looks parked it will be 0.5"-1.5" higher while driving.
2017 T@B Max S (Silver-Silver), TV 2017 Jeep Grand Cherokee Trailhawk
Regular T@b or boondock/outback axle?
Oh my gosh! So much to learn. We just got our new TV and I am headed to get the 4 pin converted to a 7 tomorrow. I need to buy the hitch ball mount thingy and have no idea what to even buy, we’ll have a T@B 320U Boondock Lite. The TV is 2018 Ford Edge SEL AWD. Any help or direction would be appreciated.
2019 Custom T@B 320 U Boondock Lite-ish We slept in 34 states, 2 countries & counting.
Hi @jkjenn, @mona and @Silver320, or anyone else with recent JGC, I have 20" wheel on my '19 JGC High Altitude with tow package. If you guys do a 8" drop, do I do 10"? Or should I just get one of those adjustable ones? How do you deal with the different heights on the air-suspension while parking, NRH(normal ride height) speed under 50mph(I think) then after(aero)? Towing and trailer camping are all new jazz to me, but I have been reading through this forum and have learned quite a bit. Really appreciate all info from everyone. Still have tons of question marks in my head though... Hope to pick up a 2019 320 S Boondock Edge in 3 weeks and like to get ready one step at a time. Thank you for all your help.
Tent to trailer w/TV: 2019 Jeep Grand Cherokee High Altitude 3.6L 2019 Tab 320 S Boondock Edge and get me out of NYC!!!
You won't have to do anything to the suspension, it will take care of itself. The self-leveling is beautiful. I only needed a 4" drop hitch and I have the boondock axle and wheels/tires.
Oh right, @jkjenn, I didn't realize that the boondock has been 'raised'. Thank you for pointing it out. Does that mean I will need a 6" drop with 20" wheels? Yes, the self-leveling suspension is awesome.
@T_BDancing - something to consider, your JGC may not be taller since sometimes tires with narrower side walls are installed to compensate for the larger rims. So the diameter of the rim + tire is the same no matter what rim size is used.
The other way to look at it is that the coupler height on the BD Edge when level should be about 18”. Use whichever drop will give you that ball height.
Richie, Mickie and Satchmo 2020 320S Boondock Lite (silver w/blue) 2019 Subaru Ascent Premium
My TV: 2018 JGC Trailhawk. The self-leveling suspension is as described by @Silver320 above.
My TT: 2021 T@B 400 Boondock.
My dilemma: The dealer set me up with a 2" rise on the hitch. It didn't look right, but he insisted it was. It didn't feel right either driving. I thing the TT is way too high. I haven't gone to scales, but my TPM showed my rear tires going up in pressure way more than my fronts whilst driving compared to when there is no TT.
I think the hitch should be neutral at best and maybe down to a 2" drop, which would mean my dealer missed by like 4".
Anyone here have a self-leveling JGC Trailhawk and a 400 Boondock that can chime in on what works for you?
@Mona We have a 2021 GC Limited with self-leveling suspension. We tow a regular 400, not a boondock.
We use a 5 1/4 drop. We have the Nivomat shocks that self level our GC. The Nivomats will only level after a bit if a drive. So we did that and at the end of the drive it was dead level.
Some GC come with air suspension that allow you to not only level for towing loads, but also your ride height in general. I am not sure which type of suspension is on your Trailhawk
Central Alabama
Jeannie
Jeannie
Jeannie
Central Alabama
https://www.amazon.com/gp/product/B0007M2PGI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Cheers,
C
2018 Jeep Grand Cherokee Trailhawk V6
veni, vidi, bibi capulus
So, 5 1/4 is probably too much drop for you.
Here is a link on Nivomats.
https://www.brakeandfrontend.com/nivomat-shock-absorbers-self-leveling-monotube-ride-control-units/
Bill
