A frame bike rack
I’m considering purchasing a “jack it bike carrier “ which installs on the “A” frame of the trailer. I would like to know if it will fit / install on my 2018 tab 320 or will it cause problems to the “A” frame/ towing.  The rack weighs 25lb and carries up to 80lb.
    mgreen2mgreen2 Member Posts: 87
    it will work but youll have to put some spacers/washers under the bolts that dont go in the Jack It frame. i installed one on my T@G but T@Bs have extra bolts. you can find pictures on the T@B, T@G facebook page. it shouldn’t be a promlem for your tongue weight unless you are maxed out or close to max now. tongue weight limit for your tow vehicle us generally 10% of the TV towing capacity.
