Well, its starting to get a little chilly at night when you are deep in the PA woods (like we were this weekend) , so its time to start using the Alde heat system ......
Brand new 2019 320S - System works perfect , no leaks . Heat and hot water work perfect off of propane and AC power .
Only problem .........when the thermostat is calling for heat and the circulation pump is running (as shown by the circular arrows on the display) , we are getting a high pitched noise . This high pitched noise is ONLY when the heat circulation pump is running, and not when the system is running in general, building and holding heat in the boiler.
We are approx 3 hours from our dealer , which makes it a little tough .
Any thoughts on this ?
Is this normal to have a high pitched noise from the system when the circ pump is running ?
Thanks for any input !
2024 NuCamp T@B 400 BD, Grey / White
0 ·
Right now its in "bed mode" . I will run out and check it in a little bit when it cools down a bit outside and report back (its 96 in the T@B now !)
Thanks .......
Here is a picture of the pump in question that has to be adjusted, should anyone else have this "high pitched whine" issue when the pump is running on with a new Alde 3020 .
Thanks again guys !
Thank you !
