For those of you that have installed a Battery Current & AH monitor.
Have you programmed the system with the ideal battery capacity from Factory AH capacity or something else?
I've just installed a basic unit { read China $30 shunt based sensor with wireless display ). For lead acid flooded batteries isn't the basic rule of thumb "you can only safely discharge to 50% capacity" . . . so am thinking if the Monitor is programmed to 50% { 42.5AH for present dealer installed battery } that will make the Battery Capacity Bar Chart realistic for a safe discharge amount. While if the Monitor is programmed to factory 85AH then I'll Need To Know that the bar chart dropping to 50% capacity is a not ideal situation.
Thoughts?
Adventures: 51 Nights: 322 Towing Miles 41,200+
0 ·
This is unit is from China. Documentation only covered wiring, everything else is "learn as you go".
