Hi, I installed one of these battery monitors on my 320, but the battery configuration and inverter on the 400 look a bit more complicated than on the 320. I'm a bit nervous. BUT, my actual question (at this point) is if that phone type cable can be shortened and the clippy end thing reattached? I guess shorter ones can be easily purchased. I only need about 3-4 feet MAX length on that as I'm installing the display right beside my inverter outlet near the stove. I hate to have the extra weight/and space of that big cord that I don't need.
Any other install tips are much appreciated specifically on the 400. I found a couple of related threads that I'm trying to follow, but I will be open to any other lessons learned.
Thanks!
0 ·
Do you have the single battery or the 6 v batteries?
Do know the display will be an issue at night, no display off mode, time for a cover addition.
Adventures: 51 Nights: 322 Towing Miles 41,200+
I was mostly wanting to avoid having to stow the extra cable, but Pthomas recommended a cable on Amazon and that is coming today. I got the display installed just now, so next is the battery connections. I wasnt feeling super confident about what goes where, so I'm going to study it more before I start phase two.
I'm confused by the distribution box! I've been studying two photos I found here on the forum but still not sure since I have something extra that I dont see in the photos. I think it's a small breaker box. If I can figure out how to downsize photos I will post a pic of my set up under there to see if anyone can give me some pointers. I'm also trying to figure out where to attach the ring end of the skinny red power cable. I already got a 12" battery cable so I know I needed that.
I installed this exact same monitor in my 320 but it didnt have nearly the stuff I see in the 400. I might have bit off more than I can chew!
https://s.amsu.ng/5jzx4zMc0DmN
https://s.amsu.ng/8vJQiGQUk2NN
https://s.amsu.ng/35bn8nzLssyN
I havent mounted the shunt yet, it's just sitting on the floor. I have a hard plastic protector box for it too.
https://tab-rv.vanillacommunity.com/discussion/8438/shunt-location-2019-tab-400
