Use a slow curing epoxy along with the toothpick/sliver of wood. Do not use an adhesive that hardens to a brittle state. Avoid quick cure epoxies. West Systems G-Flex (thickened) is the ideal product for the repair.
A follow-up question on procedure: I'm guessing one should get a fair quantity of G-Flex into the screw hole(s), reassemble (e.g., tape into place whatever had been attached) and allow 24 hours or more to set. Does this sound about right?
The shore power socket gets lots of use and is only screwed into the foam wall. The ideal solution is to buy an extra long drill bit, drill through the wall then replace the screws with bolts and nuts. Mine hasn't moved in years.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
St Catharines, ON
Brad
Concord, NC
Jeff & Amy
