As we are still waiting on the CS-S models to come in ( haven't bought it yet) we want to store it in our garage, but the overhead (pass thru) is 84 inches that is 7 ft. your standard garage. Although the actual ceiling is 100 inches. I'm getting
nervous and not sure it will clear. Just thinking if by swapping out the tires to a 5/12 ? might do it. but still not cretin, it would be an EXPENSIVE mistake if it simply can not be done. Just have to figure out how to "DROP" 5-7 inches
How do you do it? would love to see your pics
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Odessa, Fl.
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
I replace the current trailer tires with 12" x 4" Rim - 5 on 4-1/2 and with the front jack almost to the floor. I measured from ground to the highest point with the AC vent took off and I still have 86" ....so it will not get in the garage. What did I do wrong? My garage is 83.5" height. Can you guys help? I saw 9" x 4" Rim - 5 on 4-1/2 on the market. Can I replace with this Rim or this one is too small to fit ?
Thanks
a. 12" wheel without tire. I think 12" is the smallest you can fit the brake.
b. 4" drop hitch to tilt the approach angle, to protect the gray water drain.
c. 2x4 wood as a track for 12" wheel. To guide the 12" wheel, protect the gray water and to smooth the transition on the garage curb.
d. remove the 2x12 header trim to clear the vent. I modified the header trim to be removable, and bolt it back when after the t@b.
e. remove the vent cap from the hitch, 4 screws
Mine is NOT the BD version. I guess the BD might have a small height differences.
It was a tight fit through the opening, only less than an inch clearance.
