With the Alde water heater full and the trailer raised all the way up on the tongue, water (not glycol) leaks from the rear bottom of the Alde unit. This happens in reverse when I lower the tongue all the way down- water will leak from the bottom front of the Alde unit. Is this normal because of the extreme angles?
0 ·
Jeannie
https://tab-rv.vanillacommunity.com/discussion/7304/alde-drip-pan
