Out of the blue, my iPad is only showing the first four discussion topics on each page. I have looked at every possible setting, cookies, etc with no luck. I assume the problem is on my end but if anyone has a suggestion, much appreciated.
@Gherzig, are you accessing the forum via Vanilla or via the nuCamp website?
Try to clear your cache, power down, and see if that helps. Also, switch browsers. From time to time Vanilla makes adjustments that may not always mesh with our set ups. Let us know if it persists.
I am also having the same issue on my iPad when using Safari. When using Chrome for IPad, it displays correctly. Started about a week ago. No issues on my laptop.
Just an FYI: Vanilla has helped the nuCamp IT department change the Forum formatting. For those of you having issues, please let us know if anything has changed for the better with this update.
Today I did a search of the forum for "Rhomar". A number of links automatically drop down below the search box, and if you click on one of those links, everything works just fine. However, if you don't click on a link but hit enter instead (to bring up the full search history), then there are no links to the individual posts. Lots of previews of posts are displayed, but there is no access from them to the original posts.
OK, I've got it now. When you hover over the title, it becomes a link. Somewhere along the line, the color of the title has changed from blue to black so that it is not obvious that this is a link. Either that or I'm forgetting how I did things before.
This is what it looks like before hovering
Then it changes to this as one hovers over the title:
Oneonta, NY
Do you mean you are unable to scroll down and see the rest of the topics?
When I select “8 results” from the first thread, I get the same format above. However, I am able to open the threads listed after hitting enter.
