Battery and Solar Resources
ScottGScottG Posts: 1,989Moderator
Miscellaneous resources regarding battery use and maintenance.
  • Michigan_MikeMichigan_Mike Posts: 2,171Administrator
    edited January 12
    Reviving an AGM Battery
    ADMIN NOTES
    Description: Video tutorial on how to revive a deeply discharged AGM battery.
    Created by:
    Optima Batteries
    Posted by: Michigan_Mike
    Disclaimer:
     Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    Mike Smith
    Linden, Mi
    2015 [email protected] Max S
  • VernaVerna Posts: 4,639Administrator
    edited January 12
    Battery Charge Chart
    ADMIN NOTES
    Description: Handy chart that relates battery voltage to percent state of charge. Note that 12.1V is a 50% state of charge. Allowing your battery to deplete below this point can cause permanent damage.
    Created by: N/A
    Posted by: Verna
    Disclaimer:
    Verna, Indianapolis, Indiana; 2019 [email protected] 400 Boondock Lite white/red; towed by a red 2015 Toyota Tacoma V6 TRD 4x4; [email protected] Administrator.  If not now, when?
    edited January 23
    2017/2018 Factory installed Grape solar panel app if you have the Grape controller
    You can find the app in the iPhone app store by searching for "solar app nansong zhang". Once you have downloaded the app, you'll need the admin password: 135790123
    For the Android app, email [email protected] and request the app for the Grape Solar 40A Controller.
This discussion has been closed.
