Help...i bought a new tab 320 at the end of Jan . I tried to use the refrigerator propane for the first time last weekend....followed the documentation instructions to light the propane pilot...I tried and tried and could not get it to light. Any suggestions?
0 ·
I did a Google search. If you haven’t tried it yet, this is a great search method: Cooy the link, then follow with your search item.
tab-rv.vanillacommunity.com Lighting Norcold on Propane
At any rate, ours was completely a pain to light right from the beginning. Though we were able to get it lit, it always took perseverance. it got more difficult over time, and wouldn't stay lit in the end.
I finally opened the top one day, and checked the thermocouple connection to the gas valve. It was loose. Once I tightened it up, lighting the Three Way was a breeze.
Either it came from the factory loose, or it loosened from vibration on the road. If I remember right, it did repeat itself, and loosened up again after some months. I finally used a little Loctite to make sure it didn't loosen again.
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
I can't speak for the newer Tab, but on ours, lifting the stovetop exposes the electrical and gas control guts of the three way fridge.
The stovetop is held down to the countertop by anchor type toggle-bolts on each corner. These screws are hidden under the corner pads for the glass top. Turn these screws a little to loosen them, not too much, just turn them enough to swing the toggle bolt anchor out from under the counter top. If you make the mistake of loosening the screw all the way, the toggle nut anchor will fall off and be very difficult to retrieve.
Once they're all loose you can lift the stovetop up. I usually just set the stovetop aside on the sink, leaving its gas line connected.
Under there you'll see the main gas control valve (has gas lines connected to it), and attached to that main valve is also the thermocouple.
The thermocouple senses the heat of the pilot flame, and acts as a safety - if the flame goes out it shuts off the gas valve.
The thermocouple is interfaced to the pilot light by a tiny flexible metal tube. The tube is attached to the gas valve with a nut. The nut can loosen up. I put a dab of locktite on the threads and tightened it up.
HTH!
https://tab-rv.vanillacommunity.com/discussion/5485/2017-norcold-3-way-n180-3-refrigerator-cooling-issues-when-ambient-temperature-is-above-90-degrees
https://tab-rv.vanillacommunity.com/discussion/5158/norcold-trouble
2018 320S Outback
http://tab-rv.vanillacommunity.com/discussion/7717/norcold-3163-3-way-refrigerator-wont-start-on-propane-what-fixed-mine-general-diagnostic-advice
There are detailed trouble shooting steps available to pinpoint the cause of the problem.
-make sure Tab is level
-light a stove burner for a moment to pull propane through the lines, then turn off
-turn the knob on far left to propane symbol
-with your right hand turn the propane temp control knob on the far right to MEDIUM and hold it in
-with your left hand keep pushing the igniter button (pushing not holding) until the little red line is in the green, not
white. Once it’s in green you can let everything go because your fridge is now on propane. It’s finicky but it works and doesn’t use much propane. Good luck!
Leadville Colorado
