how to remove spare tire on Tab
RamblinRich
Member Posts: 2
HI all,
I have a 2007 dtq tab. I need to remove the spare tire but can't see how it is attached. There is very little clearance under thr trailer and I have read conflicting directions as to how to jack the unit.
Any help would be appreciated
Richard
Richard
These pictures show how I did it.
Another forum member suggested using a 2 x 4 to span the stabilizers to lower the spare. I had to use steel rods to keep the 2 x 4 on the stabilizers.
Loosened the nuts and raised the 2 x 4.
At that point you have to relieve the pressure on the front of the spare, but you can't simultaneously hold up the front of the spare AND lower the stabilizers so used a scissor jack as a third hand.
Then just lowered the stabilizers and jack.
2016 T@B S - TV 2004 Toyota Sienna1 -
That’s a new one-if I understand correctly, you used the jack to support the tire itself, and did not use the jack on either the axle, which I’ve read is incorrect, or the frame, which apparently can be done. I like that!John, Judi, Guinness & OD in PDX
@rajamar, that is truly awesome!!!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
You got it! It's tight quarters, but no need to raise the T@B.jgram2 said:That’s a new one-if I understand correctly, you used the jack to support the tire itself, and did not use the jack on either the axle, which I’ve read is incorrect, or the frame, which apparently can be done. I like that!2016 T@B S - TV 2004 Toyota Sienna0 -
One other thing to keep in mind - different sized lug nuts on wheels and spare. 3/4 and 13/16.
Bought a "Gorilla Automotive 1334 Telescoping Power Wrench" on Amazon that comes with thin wall sockets in both sizes.2016 T@B S - TV 2004 Toyota Sienna1 -
I stacked two columns of lynx levelers under the wheel so when each nut was removed, the tire would lower only a few inches and rest while the second nut was removed.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S1
- 957 Air Conditioning & Refrigeration
- 922 Introductions
- 410 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 919 Tips & Tricks
