What kind or # of fuse do I buy for the Alde system?
Skim63
Member Posts: 5
Question..... What #, brand or kind of fuse do I need for my 320s T@b Alde h2o system?
Thanks in advance, clueless
They are two locations got Alde fuses/breakers...
There's the 'normal' breaker-box/fusebox (converter, under the bench seat) which has a breaker for the Alde 120v and a fuse for the Alde 12v.
There are also two fuses inside the Alde that protect the 12v negative and positive legs, separately.
You should be able to determine the size and type from this thread:
https://tab-rv.vanillacommunity.com/discussion/163/fuse-inventory/p1
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Thank you so kindly!!0
Fuses for Newbies is a great resource, also. While you are buying Alde fuses....
Towed by 2014 Touareg TDi1
