Waste water hose yoke
TabbyJen
Member Posts: 3
This yoke will minimize “water wiggle” at the honey hole.
...which could prove to be bad! 🤢💩TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
Welcome to the Forums! And a first post with a useful mod!
Towed by 2014 Touareg TDi1 -
@TabbyJen, welcome and way to go!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
My bend a clear one doesn't have a handle do I just keep a housebrick in the truck bed to weigh the bend down. Nice fix from you tho.
I see that being a nasty germ soaked piece of wood you need to store and deal with. You don't know what last person did at campsite or dump station, I always assume those areas are unsanitary. It bugs me a little bit that many sites have the water, sewer and electric all so close that a little waste water spill can contaminate all three.
IMO, nothing porous like wood should be used, like a wood cutting board and raw meat, hard to sanitize after use.2019 T@B 400 Boondock Lite1 -
Welcome @TabbyJen! I actually don’t use the supplied elbow end to my dump hose. I just stuff the end of the hose down the sewer hole, as a good friend who taught me to dump my tanks suggested. So far I haven’t camped where the elbow is required but I carry one just in case. You did really nice work on your mod, however I have to agree with the sanitation issues presented using wood. Thanks for sharing your mod, and I look forward to seeing many more! Tabs are fun that way!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red2 -
You could put a couple of coats of paint on it. I have met people who are so concerned they spray the drain area with a water and bleach mix including the water faucet. In over 40 years of RVing I have never felt it was that big of a deal.
- Hash T@B Fun
2
- 426 Service/Maintenance & Recall Notices
