Dying battery
14 foot T@B trailer battery dies while parked
  • falcon1970
    falcon1970 Member Posts: 758
    While parked in your driveway or when out camping?  If in your driveway, have you been leaving the battery disconnect switch on without shore power?
  • Michigan_Mike
    Unless the battery switch is off or the battery is disconnected it will drain down via LED circuitry, the TV, Stereo, etc.  You might want to buy a battery tender and this will keep your battery charged up while not in use.  Battery will drain if not isolated from the trailer circuits and this is normal and similar to leaving a car parked for a period of time.
  • ChanW
    ChanW Member Posts: 3,171
    Is the 3-way fridge on?
    You probably should give us more info.
    Year of Tab?
    Accessories powered on?
    Age of battery?
    Connected to your vehicle?
    Parked for how long?
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
