Where did you mount your autowbrake controller?
For those of you who have an autowbrake controller on your T@B, where did you mount it?  The tongue on my 2015 320U is only wide enough for two screws to mount, not four.  I'm hesitant to put it underneath the trailer.  Thanks!
2015 T@B U - A Sn@il's P@ce
  • rajamar
    rajamar Posts: 112
    I lashed ours vertically to the battery case. Strapped it on with horizontal zip ties. It's held securely in place by the nylon strap that holds the battery box cover in place. Mounting it there keeps it close enough to the junction box for (relatively) easy wiring connections.
    2016 T@B S - TV 2004 Toyota Sienna
