Good morning all.........we don’t normally watch a lot of TV while camping but once in a while if a storm blows in it is nice to throw on a movie, and kick back with a glass of wine. However most of our camp sites rarely have cell service, and even rarer to have wifi, so I found this
https://www.amazon.ca/Compatible-Adapter-Digital-Adaptor-Connector/dp/B08HDHGWT4 so we could pre-download a few Netflix movies before leaving the house and watch without any cell or wifi service
The unit does require power, yes we do have the factory installed inverter but the inverter probably uses as much power to run it as this adaptor draws, so I installed a 12v USB plug
https://www.amazon.ca/CHAFON-Charger-Colorful-Voltmeter-Waterproof/dp/B08C7T27LG close to the Jenson radio, and we now have HDMI movies c/w stereo sound.....so far works great but have only tried it in a couple times in the driveway as we have close to a foot of snow on the ground, looks like our camping season is over until next spring😂 following are a couple pictures of the installation
Turn off the battery disconnect and remove the Jenson stereo.......NuCamp does a great job of marking wires
Drill a 1 1/8” hole and install the USB plug in........NOTE make sure you can reach the back side of the USB plug from the Jenson cut-out before drilling the hole, I almost drilled to far away, was just able to get the backing nut on😳😳
Install the USB port, and splice in the power and ground wires
Turn on battery disconcert and make sure everything works
Tidy up the wires and enjoy
Installed a couple command hooks for when not in use
Simple installation, maybe took 2 hours all total
Couldn't you use the USB in the Jensen, instead of adding a separate one?
I use it to power my FireTV stick...
Just wondering.
@ChrisFix......never thought of trying the USB on the Jenson, none the less the newly installed USB port has a on/off switch so no parasitic draw when not in use and always can use more charge ports 😁😁
@Verna ......that looks like a great unit, let us know how it works
Definition of Success….”moving from failure to failure without any loss of enthusiasm” (Winston Churchill)
https://www.amazon.com/dp/B07M61X8N3 )
.. whic connects our Galaxy Note8 phones via HDMI cable to the T@B television. This mirrors whatever is playing on our phone screen, and works great for playing saved video, photos, etc.
We will be at Nucamp in Jan so will have them try it but hoping it is something I can get figured out before then.
thanks!
There is no special setting...HDMI input is the correct one to use the Jensen's HDMI port to play on the TV.
Do you have a Roku or FireTV stick...something without a cable? That will rule out if the cable you are using between your iPhone or laptop is the issue or not.
It works perfectly for me with the same model of 400. I use both my laptop with an HDMI cable, and a FireTV stick that plugs directly into the Jensen's HDMI port.
Then set the TV input to HDMI, then mirror the device to the TV. It seems to help to plug this in before turning on the TV. Be sure to set the TV to HDMI before connecting a device to it, otherwise you may need to turn off the power and then turn it back on. Be patient, the TV seems to be the slowest link in the process.
Thanks, Jerry
The 2021 models (which @xdr was asking about) have an HDMI port built into the front of the Jensen...which is pre-wired and connects to the TV. So no need to connect to the TV directly.
Thanks, Jerry
I've only been able to watch downloaded movies from Netflix or Amazon Prime. When trying to stream I've gotten error messages saying transmitting to another device is not allowed, or something like that.
The Amazon cable didn't work (even though it's touted as "Apple"). I show the link below for the bogus cable. The TV monitor said "no signal". I switched to the official Apple cable and the TV responded instantly with an image of my iPad. I did this switch between the 2 cables 5 times and got the same result. I returned the Amazon cables.
@Marceline thanks for explaining about the DRM chip.
https://www.amazon.com/gp/product/B0881N2VCV?ref_=pe_1811570_136791410_E_Asin_Title
iPhone 11
Verizon unlimited
Official Apple HDMI adapter (with power supplied from T@B 12v outlet.
Tampa FL
Tampa FL
Wonder if its something Apple is blocking because of digital rights?
Tampa FL
