Blowout air compressor connector piece to RV
jules2go
Member Posts: 172
Sorry for not knowing the right lingo, but I need a part for the end of my air compressor hose that goes into the city water connection (not the thing that screws into the city water outlet, I have that). I have to be able to do the blowout task alone, so I need a handle that I can squeeze and set it to stay in place to deliver the air (like a garden hose sprayer) so that I can run around and do all the valve opening/closing inside etc. Looking for part suggestions. Thanks!!
2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
2019 Toyota Tacoma
Asheville, NC
Hi Jules2go, my air compressor automatically cuts itself back on when the pressure drops. This is the fitting on my air compressor but you have to take off the silver end and replace it with the quick disconnect. It's locked on.
@pthomas745 ...maybe. I don't think I need all of those pieces, but it's only 13.00. Thanks.2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"0 -
I agree, I was looking at that as an example. You should already have the adapter to the compressor, this looks like an easy way to control the situation a little.
Towed by 2014 Touareg TDi0
