Beeping
banjer54
Member Posts: 21
I'm not sure what is beeping inside my camper. It was put away in October. Battery is out and propane is shut off. It beep every once in a while. It just started today. I guess it the LP detector?
With no battery, the LP detector won't work. The gas detector also has a series of flashing lights that you cannot miss when they go off.What does alarm, just like your home, is your smoke detector, which has a simple 9v battery. Don't know what year you have...but look for it in an elevated location.
Towed by 2014 Touareg TDi1 -
Thanks it a 2019 and it was the smoke detector. it took a while to find it, I have a lot of things stored inside for the winter. It will get a fresh battery come spring1
- 424 Service/Maintenance & Recall Notices
