Gas quick connect
hikerchick
Member Posts: 35
I am trying my outdoor stove and my quick Connect for the first time my gas lever is on and my gas tank is on but it’s not working any help?
What stove are you using ? The quick connect has low pressure gas, already reduced by the regulator near the propane tank. If the stove has its own pressure regulator it won't work.2
Quick connect pressure = .5 p.s.i.
Portable propane camp stoves that use bottled propane have regulators that pass 5 to 10 p.s.i.
So simply, not enough pressure1 -
Check internet for grill modification tips. For example I have a Weber grill which has a regulator. Multiple vids online to mod grill for rv use.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
I purchased a gas fire pit that I plug into the gas quick connect. As line is already regulated, I removed the regulator on the fore pit and it works great. Same should apply with a stoveUltimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California0 -
Use the opportunity to purchase a 22" Blackstone griddle. You can bypass the regulator on the griddle and use it with the quick connect at the back of the camper, or you can use it with an unregulated propane tank. And it's the bomb! Best purchase I've made. I love cooking on it!2021 T@B 400 BDL aka Little Joe
2019 Tundra Crewmax aka Hoss
SE Louisiana1
