A somewhat indelicate question. We are trying to get a handle in this living in an RV thing and it occurs to me that it might be a good idea to use the wet bath toilet and black tank only for #1 and use the campground facilities for #2. Or for emergencies, something like this:
http://www.amazon.com/Reliance-Products-Double-Doodie-Toilet/dp/B0024O0W94/ref=sr_1_1?ie=UTF8&qid=1438182552&sr=8-1&keywords=RV+toilet+liner which could be disposed of with the trash.
Is this feasible? Would it make dumping the black tank a little easier to deal with?
I bought some doodie bags from walmart for #2 emergency: http://www.walmart.com/ip/Ozark-Trail-Double-Doodie-Bags/14550463
and some dog training pads for #1 emergency: http://www.walmart.com/ip/Hartz-Home-Pro-Dog-Pads-100-Count/36266499
So far, I haven't used either one of them....
I just don't want to deal with dumping and cleaning.... I got some Odorlos packets just in case, but I don't think I'm going to use it.
I try to avoid the dump station if it's busy but most of the times it's not so don't feel any pressure to hurry things up.
1) Do I hook to the grey tank all the time, and only connect to the Black when we ready to leave on the 3rd day?
2) Home to campsite is only 90 min so I plan not to fill the water tank when starting the trip. And use the campsite water connection to fill up the tank on arrival. And drain all faucets prior leaving (so with empty water tank on driving home). Is this the right way to do?
3) What's the water filter you use for the water connection hose so the water from faucet is "drinkable"? Or I just stack the refig with water bottles?
Greatly appreciate your advice, and TIA.
Don't fill the water tank - not needed. You just hook the white hose to the spigot on the post and turn it on and your interior faucets work. No pumping needed (but get the pressure regulator - less than $10 to protect your plumbing).
we got this filter:
http://www.campingworld.com/shopping/item/tastepure-kdf-carbon-water-filter/18478
If I'm recalling correctly the sequence is: camp faucet -- pressure regulator -- filter -- white hose -- T@b attachment port. You can't see the filter and faucet on the right, and I forgot - we inserted an extra faucet on the outside where the hose goes into the T@b on the left. Wait. That's the little pressure regulator gizmo by the add-in faucet at the entry port too. So it's camp faucet, filter, hose, pressure regulator, add in faucet then T@b port.
There re are things in life to worry about and be nervous about learning, this should not be one of them.
Two questions:
1. Why not connect to the grey tank all the time? As it allows us to take as many showers during the 100+ degree and humid days. And move to drain the black tank (using the method you mentioned to add water via the shower hose), then again to connect back to the grey tank and using the same method to wash thru the hose thru the grey tank drain?
2. I bought from Amazon Camco 39761 RhinoFLEX 15' Sewer Hose Kit with Swivel Fitting per suggestions from the Forum. It compressed to 54 in so do not believe it will fit in the battery compartment. What's the best method/way to store it?
We will be in Galveston 8/3 for our very first camping trip. Hope to see you TABers there.
Portable toilet kit --
http://www.campingworld.com/shopping/item/go-anywhere-toilet-kit-12-pack/24397
As others have written, dumping is easy with gloves and a Rhino system. I've read to dump black first and then grey - that allows dish and other soap to "clean" the hose.
The grey tank in the 2014s and earlier is pretty small and I did run into an issue with filling it up on Memorial Day weekend because I was cleaning vegetables and washing dishes. It was a lesson learned about water conservation.
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
That's a lot of clean veggies!
I've had my T@B for a little over 3 weeks and I just came back from almost 3 weeks of camping. I used a portable gray water tank only for the first 10 days, and used the Double Doodie bags in the toilet for #1 and the campground facilities for during the day and my own facilities at night. Easy to dispose of.
So, the portable gray water tank was easy to dump at the dump station. Learn in steps.
Last week at Tearstock, I used the portable gray water tank for about a day and a half, and then I started using both the gray and black water tank. What a better way to learn than with so many experienced people around me?
So, as I was leaving the campground, I emptied the black water tank first, then the gray tank to rinse the residue from the black water tank. It worked. I love those blue nitrile gloves!
Learn in steps. Don't use the black water tank first, just the gray water. It's just sink and shower water. Or just jump in with both feet and use them both. You'll be amazed about how much easier it is than you thought it would be.
