Is it safe to just drain your tanks to winterize?
CCC
Member Posts: 118
Been getting mid 20's here in GA for a while in the winter. Any real reason to do anything other than drain the tanks?
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
North Georgia
I’m up in TN and we have freeze warnings coming. Drain tanks and either blow out plumbing or run RV antifreeze thru your system using your water pump. Lots of plastic plumbing parts can freeze and break.2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
Here is a recent thread with more info
https://tab-rv.vanillacommunity.com/discussion/16338/first-time-winterizing-one-concern#latest
2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab -
Yes you absolutly need to do more than just drain the tanks. You need to winterize. There are videos posted here in how to winterize that are tailored to your model.
- 916 Introductions
- 72 Teardrop Groups & Links
