Have a 2018 400, I just bought and I think the two 6 volt AGM batteries are original. They on shore power show 4 dots on the control panel inside. When remove shore power within three days lights on panel will go to two, nothing on in camper. If cut disconnect switch off very little change.
i have not removed the cover over the batteries to see what amperage/ brand they are. Question is once remove cover how do I check voltage to see if good or bad? If need to replace, what type of AGM Is preferred brand, how to make sure installed properly, and can I use a trickle charger on these types of batteries as I did with 2015 320S with wet battery. Not much room where they are under the bed and with the battery disconnect switch.
Thanks for any help rendered
jetman
0 ·
