The 2023's 320's with the "lithium upgrades" are showing up.  Can any of you with the Multiplus show us how the VE Bus Smart works to turn on and off the inverter and charger, etc?  Victron makes wonderful products, but their manuals and documentation seem to be aimed at rocket scientists.
0 ·
Yes I leave the inverter off until needed when boondocking. I have not determined the parasitic draw.
On = "Auto Mode" and allows automatic handling of the internal transfer switch
Inverter only = keeps unit running off batteries only, disabling shore/gen power pass through
Off = completely shut the unit down while still attached to power
Charge only = only allows charging the batteries, does not allow pass through or battery power
The Multiplus has a physical switch on the unit itself. I do not have a secondary physical on/off switch. I just control everything through the app.
