Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Leaking front window TAB 400 BD
jggigi2009
Member Posts: 6
Has anyone had trouble with their front window leaking during rain along the top over the table and cushions?
I have. The black rubber seal on ours wasn’t fully seated and created a valley for the water to collect in. I opened the screens and used a rubber mallet to get it fully seated along the top. Could be your issue.Rich2019 T@b 400
Same here. Dealer fixed it under warranty by adjusting the rubber gasket in 2021. Haven't had an issue since.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota -
Same issue here. Ours was due to the butyl tape pulling away from the aluminum body. Water was running off the top of the window and down the rubber seal but because the butyl tape had failed it ran straight down the inside of the window frame and out the bottom to the inside of the camper. I had to pull the rubber seal back and reapply some butyl tape but all seems well for now. To be proactive I redid the stargazer window’s butyl tape at the top corners as well.2021 400 BD
2020 Tacoma TRD Off-Road -
Horigan above hit the nail on its head. My front and back windows were not fully seated and or somehow jumped out over a bump.
- 135 Help - Computer & System
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
