questions on 2017 Tab 400
Anyone here own a 2017 Tab 400?  Nucamp does not have specs for older years going back past 2020.  Can't find dry or wet (battery/propane/full watertank) weights.   Cool Cat A/C?  3-way fridge.   Looked for Values and J.D. Powers doesn't have anything older than 2018.
Any info on this model appreciated. Thanks
2018 Tab 400
    MuttonChops Member Posts: 2,078
    Believe model-year 2018 was the initial TAB 400 product.
    RV Model years are not standardize, in general units built between June 2017 and June 2018 would be called model-year 2018.
  • lkc001
    lkc001 Member Posts: 881
    edited July 2024
    oh, OK--so he must have purchased it new in 2017 and it was actually a 2018.   Good to know---still looking for correct tongue weight info.  Posts on these for sale are all over the place from 315# to #472. . . .
    Thanks!
    2018 Tab 400
  • lkc001
    ok--so received a prompt reply (nice!) from Nucamp--stated that "while I do not have specs, I have done some research and the closest estimate we have is as follows:"
    Tab 320S---159#
    Tab 400---457#
    Again this is for older than 2020's
    I followed up and asked it this was a dry or wet weight--will add more info if I find out.
    Good info for the group!
    2018 Tab 400
  • lkc001
    ok--new response--she said dry weights, which I guess would mean it includes the attached spare but without propane, batteries, water, etc.
    I'm going to ask if anyone here has actually gone to a scale with wet weight on a 2018-2019 for weights.
    2018 Tab 400
    pthomas745 Administrator, Moderator Posts: 4,700
    @lkc001 Another hint on the "model year" will come from the "build date".  The gray sticker on the driver's side of the tongue.  "Usually", like MuttonChops mentioned, the 2018 is the "start" of the 400 model.  There are more than a few owners mentioning they have a "2017" 400.  They may be mixing a "build date" with a "model year."
