2020 Tab 400 Boondock Solo Question
bayernfan
Member Posts: 46
Would a 2020 Boondock Solo be considered a pre-pandemic unit? I've read that Nucamp build quality experienced a noticeable slip during pandemic era and I'm trying to avoid those years.
2024 T@b 400 Boondock | 2024 Honda Ridgeline | Dallas, TX
You can check the build date on the label on the trailer tongue as that year was likely a 2019 build.
My 2019 has a build date of Oct 2018.
Bigger question might be the AC. The 2020 year was the Air8 year and many folks felt it could not handle heat and humid climates.
FYI the CoolCat works great.
Good luck2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab -
The 2020 Solo model received the CoolCat. I’ll ask the seller to check the label. Great idea, much appreciated.2024 T@b 400 Boondock | 2024 Honda Ridgeline | Dallas, TX
- 916 Introductions
- 72 Teardrop Groups & Links
