Is there a hot water bypass lever in T@B 400 from 2023?
Larami
Member Posts: 10
We previously owned a 320. The hot water bypass lever was located in the Nautilus compartment wall in the 320. We’ve looked under the bed panels, in front under storage, no red lever hot water bypass. We’re not missing a location for the lever are we?
The "bypass" valve for the Nautilus P3 in your camper is part of the Nautilus plumbing. In the first couple of pages of the manual there is a page that describes the operation of the various colored Nautilus "handles". In these newer trailers, the "Red Handle" performs the older "bypass" function. In combination of the other various "handles", of course.Page 4 of the P3 manual.
Towed by 2014 Touareg TDi3 -
Thanks for clarifying the hot water bypass is now simply the red switch/handle in the Nautilus and not like the older bypass. You’d think this would be more clear as a change from previous T@B editions.1
