2020 T@b 400 With Coolcat
I have the 2019 with CoolCat and the unit is under the driver side dinette seat with the exterior vent on that same side at the front of the trailer. My knowledge is that the Air8 unit in the 202 400 is under the bed and thus the dinette area is storage and thus no exterior vent.
So a simple exterior pic of the driver side of the 400 should clearly show the difference,2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
This is a picture of our 2024 400 . You cant miss the HUGE Cool Cat A/C vent / grate on the off door side of the camper (its black on ours) . Its right at the front , drivers side . 2' x 2' vent (approx.) ...... its huge ! If it has this huge vent ......it HAS a Cool Cat . The actual Cool Cat A/C unit is located under the drivers side dinette seat .Pekoe1111 said:Can you please confirm that a 2020 400 with the square vent at the front of the driver side has the desired Coolcat A/C unit? This is the one that is NOT under the bed, correct?Thanks!
If you find a 2020 400 that does NOT have this huge vent / grate , it DOES NOT have a Cool Cat , but instead will have the Air8 that vents out the bottom of the camper . Unit is located under the rear bed if its an Air8 .
HTH2023 Ford F150 Sport 3.5 Ecoboost
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
