Thanks
qhumberd
Moderator
Connecting T@B to Toyota Rav 4 SE (plug in hybrid)
mash2
mash2 Member Posts: 584
Does anyone have experience with connecting
Toyota hybrid.  Dealer isn't helpful and I've seen conflicting info on ability to use 7 pin connection on this car.  Any experience info would be appreciate.
  • Horigan
    Horigan Member Posts: 862
    One option is to forego the 12V+ charging line and just run brake control and ground to the 7 pin, along with the lights of course.  That eliminates the need to find a 12V source on the RAV4.  I've pulled the fuse for our 12V+ since I don't want to worry about my T@b lithium battery interacting with vehicle charging system.  Note I have solar that charges while traveling.
    A good RV place may have more knowledge of wiring to Hybrids.
    Rich
    2019 T@b 400
    Bellingham WA
    pthomas745 Administrator, Moderator Posts: 4,526
    Which vehicle?  Have you tried any of the various Toyota forums?  Generally car dealers are helpless at anything involving towing.
    Here is a basic search for "Toyota Hybrid to charge travel trailer battery".  Should be some answers here.
  • Bill&Suze
    Bill&Suze Member Posts: 174
    The issue of wiring connection aside, perhaps a more important consideration is the RAV hybrid's towing capacity. A quick online search for RAV4 hybrid towing capacity seems to indicate that the 2nd generation model available since 2019 has a capacity of 1750 lb while the RAV4 Prime ups that to 2500 lb. What's the lightest T@B weigh?
    Susan & Bill, Yarmouth, Maine
    2024 Kia EV9
  • mash2
    I have an old TB (2004)  rated at 1900 lbs.  Not looking to haul large distance or rough terrain, just local jaunts....At one point used a 2012 Forester and it generally worked fine...
