Stove or Regulator?
Jax0913Jax0913 Member Posts: 67
We have a 2018 400 and are having an issue with the stove not lighting. With everything off it is getting gas but not a flow to light the stove, it just pulses then goes out. The Alde works fine. With the Alde on, the stove gets little to no gas, making me think it is the RV regulator. I did remove the burners and clean the tips no luck. I took a video of what happens with the Alde off but it won’t let me attach the video. I read through some of the feeds and saw a few posts on this. I also had to replace the supply line to the Regulator. I’ve opened and closed the tank, slowly and disconnected, we have also traveled shaking everything up, still same. Any ideas?
2018 T@B 400
2020 Toyota Tacoma Double Cab
  • MuttonChopsMuttonChops Member Posts: 1,847
    I've got no problem advice, sorry.
    For the "adding a video" the only method I've found is to place the video on your youtube channel and then place a link in the forum post.
  • TourDeForthTourDeForth Member Posts: 119
    If you’ve already checked for leaks at your fittings you could purchase an off the shelf propane regulator, Home Depot sells them with a 3 foot hose for under $20. Bypass your trailer regulator and see if the stove functions.
    Or try a manometer to check the output pressure from your regulator and see if it has issues, some regulators can be adjusted. Here’s a short manometer explanation https://youtu.be/i41-re5VjBY
    If you can’t rent or borrow a manometer there are cheap ones online around $40…
    2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4
    John, Northern California
  • Jax0913Jax0913 Member Posts: 67
    Thanks @TourDeForth! Good idea to bypass the regulator and connect directly to the stove. I will give that a try.
    2018 T@B 400
