What's the trick for installing the vinyl trim?
Over the past six years I've had to replace the vinyl trim (3 times) that runs from the front bottom of the trailer, through the push/pull handle, over the top and finally to the rear bottom. The first time I used trim from Amazon and within two years it was cracking. So I got some from a local RV dealer. Last year it came undone while on the road, so I ordered a thicker/heavier version of it from Amazon and installed it on both sides. Last week while on the road, one side came loose from the rail and was flapping in the wind, even though it was still attached by the screws under the front, and back and under the handle.
So how do I install this and prevent a repeat of last week? Glue or silicone sealant on the screw heads?
Thank in advance for any guidance.
Thanks, Jerry
Use some Shoe Goo adhesive every few inches. It won't move again.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1 -
Never heard of Shoe Goo, I will try it. But should it be used on top of the screws or placed directly on the trim or on the frame?
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.0 -
Just a dab underneath the vinyl trim every few inches.
Carol
MOUSE-KE-T@B
Harvest, AL1
