My DH made the mistake of grabbing the edge of the rear shelf (as installed in the newest T@Bs) and using it to scootch himself up in bed. It popped right off. It looks like the plastic hinges are soft enough that they came right off the screws.
@Verna and others, what is the best way to fix this? I can easily put the shelf back with the plastic hinges, but I'm not sure it will hold well now that the holes have been stretched, and in any case the plastic hinges look a bit dodgy. Would metal hinges work okay here?
You can see here the screws are still in place. (Those additional holes came that way, someone must have drilled in the wrong place.)
Sterling, VA
Sterling, VA
For now, I put the screws back with washers and DH has strict instructions not to pull on the shelf.
Photomom, with patience, a guide and some clamps, you can accurately cut the board to the lengths. Hollar if you need some help with instructions. I have a compound miter saw so it would take me longer to set the saw up than to make the cuts
The veneer on that pretty wood is really thin and tears out easily. I speak from experience (or rather 'inexperience' - I didn't fare so well at it).
Verna can tell you better how to cut it... B-)
Cut as far as your blade will allow, then flip the wood over to finish the cut. You will have to be careful to make a straight cut because it will be very easy to be off just a fraction of an inch. If you can clamp the wood down on your saw (ON ONE SIDE OF THE BLADE ONLY!) after you have meadured 3 or 4 times for the second cut, it will stay in place for your cut. If you don't get a straight cut, don't worry. If you're used to cutting picture frames, etc. you can always put a piece of trim board on the end to make up for a goof.
Hollar if you don't understand or need more help. You can always ship it to me and I'll cut it for you
I finally figured out what to do with the enclosed space under the shelf - we'll use the two end sections for PJs and use the center section for extra paper towels and TP. Having the shelf lift in sections will be great.
Thanks, @Verna, for the advice about sawing the shelf. I used masking tape and cut with a 60 tooth blade in my miter saw. My cuts look better than the factory ones on the ends!
Now I need to do something to hold them open - I wonder if the sections are now light enough for the famous "spring mod" to work?
Our Tab came with no boxed areas or outlets on the ends of that shelf (those boxes enclosing your outlets). Ours was before LG made that design decision. I like that look, and am envious of the outlets.
It seems the space right beneath the outlets could each contain a small storage 'nook', for a cell phone, or the entertainment remote controls, or...
So is your tank mounted above the level of that back shelf? Ours is right below the shelf.
Photomom said:
Closing the books on this mod :-)
