WFCO power converter?
zorro
Member Posts: 7
Which model of WFCO power converter is recommended to replace the existing Parallax power converter & will it fix in the existing cut out?
Zorro, the factory would be able to answer your question quickly. Their phone number is on the right and Pleasant Valley is the name of the factory. They are there until 3:30 pm EDT today. Try selecting warranty, and ask for someone who could answer this question for you, as Ed, Marvin or Austin would probably be able to answer it. Be sure to give your year and model of T@B available.Verna, Columbus, IN
Our 2014 CS came with the WFCO 8735. I would recommend going with a progressive dynamics model however, because they charge your batteries MUCH better, and they make a model that is a direct replacement for the 8735.
