2018 T@B CS-S Solar Panel Option
Tom
Member Posts: 2
I understand that there is a 150 watt solar option available for the 2018 T@B CS-S for $863. However, I can not find any information on the option. Is it roof mounted and if so how about some pictures. Who make the solar panels that will be used. What solar charge controller will be used.
Tom, You might want to direct that question to NuCamp directly to get more info. Look to the right under Categories, go to T@B Contact Numbers, and give them a call would be my suggestion. Hope this helps you.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1
