How are the guylines attached to the xl visor
I just received the xl visor for my tab but I see no way to attach the guylines to the visor. I watched the installation video from Paha Que and it states that the guylines are pre-attached, but mine came shipped loose and I see nothing on the visor to attach them to. Am I missing something or was I sent a defective visor? First the fridge doesn't work in my t@b, then the Alde starts vibrating so badly that it wakes me up and now this. What is it with quality checks these days?
PJ in Arizona 2014 Tacoma. 2015 T@B S
  • XPADREX
    XPADREX Member Posts: 311
    If you look in this photo, you can see the little tabs it is attached to (runs through, if I recall):
    https://us.v-cdn.net/5021717/uploads/FileUpload/66/4fbf767d8fc8857b41031a79875262.jpg
    LOCATION: Fort Raccoon; UNIT: 2014 T@b S M@xxxx; MISSION: To have fun, make a difference, and make some friends along the way. Organ Donor Recipient- forever grateful.
  • LittleredTab
    LittleredTab Member Posts: 21
    Thanks for the photo. That is the same as I saw on the instruction video, however the visor I received does not have the little tabs.
  • Eji
    Eji Member Posts: 12
    Hello, I got the tent for my 2018  Tab. Do I need to remove the plastic trim in the kider rail and leave it off? or do I reinstall it when I am done camping ? Help please.
    I think most owners remove the plastic and dispose of it....it really doesn't serve much purpose.
  • T@Balong
    T@Balong Member Posts: 317
    Leave it off, if you camp often, it will be  a nuisance to re-install it in between uses of your keder rail.
    States Visited Map
  • ericnliz
    ericnliz Member Posts: 4,437
    edited November 2017
    @Eji, Left mine off after re-installing following the first time we used our tent. Just leave it off, (kind of a pain in the rear to put back in, especially if it's cold! :o) and save it for re-install IF you ever decide to sell your T@B. ;)
  • Eji
    Thank  you for the great advise, I camp often so Ill leave it off.
