Solar Use
sdenhof
Member Posts: 43
I have a Tab 400 with solar installed. This constantly charges the battery correct? Nothing to turn on or adjust?
2018 Tab 400 towed by 2013 F150
Evanston Wyoming home
Do you have the solar app on your phone? Although there is indeed nothing to turn on for the solar system, it is wise to monitor your rate of generation and your battery level. You may find yourself in situations where your rate of usage exceeds your rate of generation and the potential for a drained battery.Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 400
- 916 Introductions
- 72 Teardrop Groups & Links
