Does anyone have thoughts on keeping the tab from freezing without winterizing? We wanna use it for ski camping-is it unrealistic to try to do that with water and bath? Are there no modifications that'll allow us to have those options in winter? I dont mind taking it apart a bit to make this possible, but I can't even tell right now whats freezing and what to address. Has anyone done this?
0 ·
I stayed winterized on the trip to Arizona, using two 2.5 gallon jugs of tap water for cooking and the toilet. I visited the RV dump every morning to empty the tanks (it only got down below 28* one morning) to make sure they didn’t freeze. I kept RV pink antifreeze in the p-traps during the day.
I was not winterized on the way home, with temps staying 31* and higher, and mostly above 35*. I used city water until I got to 33* and then I opted to use the water in the fresh water tank, rather than risking bursting a water hose. I do need to winterize before Friday as the T@B will be cleaned totally out and cleaned up by then.
sink or shower drain for gray water dump valve.
