How do I know what Model I have
I just got a used T@B.   I cant seem to find out what model number it actually is, nor can I find a sticker on the unit to tell me.
FJB
2015 T@B 320Q
2009 VW Touareg
Two Fiddles
One Bicycle
One sewing machine
  • Dalehelman
     Describe the floor plan and year and someone can tell you what model it is.
    1. Hash  T@B Fun
  • Homebodyatheart
    @Fiddlerjoebob congratulations and welcome to the Tab family! If it has a rear hatch with kitchen it is a CS. If the CS has a shower and toilet(wet bath) it is a CS-S. If it has kitchen and wet bath inside it is the S model. If it has no kitchen or bath it is the U model. If it has a raised frame and yakima rack on the back it is the Outback model, now called Boondock. There is the Sofitel, high end S model, and the Tabitha, S model with unique interior but is no longer made. When you need help on the forum it is helpful to have the model and year of your Tab included. Different model years have different features. Pictures are always helpful, too. Hope this helps!
    pthomas745 Administrator, Moderator Posts: 4,685
  • Fiddlerjoebob
    Fiddlerjoebob Member Posts: 6
    Ok, thanks...I have the U model, and I found the VIN.  And, its a 2015, which I knew.  So do I refer to it as a 2015
    'T@B U model"  ?  Is that sufficient nomenclature? What about the numbers like 400 and such I see on posts?  Do I have a number like that?
    2015 T@B 320Q
    2009 VW Touareg
    Two Fiddles
    One Bicycle
    One sewing machine
  • Verna
    Verna Member Posts: 6,876
    @Fiddlerjoebob, you have a 2015 T@B 320, U model.  If you had a bathroom, it would be an SU model, but you haven’t mentioned the wet bath (S means shower).
    I’m not sure the U model came with a bathroom.......
  • Fiddlerjoebob
    Right!  no bath.  Inside kitchen.
    So so it’s the 320. Thanks.  Can’t wait to get on with it this summer.
    Fjb
    2015 T@B 320Q
    2009 VW Touareg
    Two Fiddles
    One Bicycle
    One sewing machine
    MuttonChops Member Posts: 2,072
    I just got a used T@B.   . . .
    Welcome !
    You might find it helpful to download a copy of the Little Guy Marketed 2015 T@B Sales literature for your camper files.
    http://library.rvusa.com/brochure/TAB_Brochure_2015.pdf
    http://www.tabownersclub.com/wp-content/uploads/2015-Tab-T@B-Camper-Catalog.pdf
