What setting is "colder" when running Norcold on gas
tombeaux
Member Posts: 63
We have only run ours on shore power but will be boondocking some soon. The Norcold settings on propane are High, Medium and Low. Does "High" mean maximum cooling and "high" use of propane? Or, does that mean HIGH temperature inside the fridge??
2018 T@B 320S. 2017 Toyota Highlander AWD
tombeaux said:. . . The Norcold settings on propane are High, Medium and Low. Does "High" mean maximum cooling and "high" use of propane?Norcold Owners Manual, page 5:The gas control sets the temperature setting of the refrigerator when operating in the GAS mode. To change the temperature setting, push and turn the gas control to either HI, MED, or the LO position. HI is the coldest temperature setting.Also
Adventures: 61 Nights: 417 Towing Miles 51,0501
