Atwood Heater Service Manual
NomadNomad Member Posts: 7,209
ADMIN NOTES
Description: 2004 edition of the Atwood Furnace Service Manual. Atwood furnaces were installed in Dutchman era T@Bs and some early LG/PV T@Bs. LED fault codes are found on page 13. Additional troubleshooting tips are included in the comments.
Created by:
Atwood Mobile Products
Posted by: Nomad
Error code chart posted by Bob Fuss.
    MMcDMMcD Member Posts: 1
    Have a T@B 2005 CS trailer.  The heater is not working and there is a light signal error code for 'limit switch/air flow problem'.  Looking for help from anyone with a similar problem and how you fixed it.  Thanks!
    rfuss928rfuss928 Member Posts: 935
    edited January 2018
    First, there is a reset button near that light - try pushing that.
    If the fan sounds like it is running , it could be a problem with the "sail switch" in the airflow from the blower.
    IIRC it can be accessed from the side along the bottom toward the outside wall.
    It looks like this:
    Furnace Low Air Flow Switch 36680
This discussion has been closed.
