Has any replaced black tank in Tab CS-S
dont ask why, it is a long painful story. lets just say the remaining stub out of the back tank is not enough to work with. Hoping someone has ideas or can shed some light here. Many thanks in advance. I looked through 30 pages of forum discussions and this looks to be new
  • Homebodyatheart
    Homebodyatheart Member Posts: 2,516
    Maybe @Dalehelman can help figure this out with you. PS- I think you've got enough campfire stories for a while. You can stop now!  :)
  • Tabnero
    Tabnero Member Posts: 253
    I will send Dalehelman a message, thanks. Not sure what the rest of your message means, thanks anyway
  • Dalehelman
    Pictures please
    1. Hash  T@B Fun
  • 4ncar
    4ncar Member Posts: 1,072
    ...oh this is about to get good!!!
    2018 320S Outback
  • jkjenn
    jkjenn Member Posts: 6,422
    Agreed!
    @Tabnero sorry for your current pain. I would not hesitate to contact uCamp, either. They are very good about giving guidance to owners.
  • Homebodyatheart
    @Tabnero sorry for the confusion! It's my theory that our learning experiences with our Tabs, especially the ones that you can't laugh at yet but will later on, make for great campfire stories. We've all got them, but some are better than others, and it helps the new owners learn, too. Either way, I'm sorry your Tab is damaged.
  • Tabnero
    @homebody, ok now i get it. when I stop throwing things it will be a good story. and it starts off "no sh*T guys there I was"
  • Tabnero
    @Jenn, I have an email to them and when I get a break today will call them. Thanks
  • Tabnero
    Pictures please
    there is nothing to see. the stub that exits the floor was cut at odd angle and now you can not attach anthing to the outer housing. The 3 in stub out leaks. I am furiously looking for a slip in pipe I can glue to have a complete seal and enough of a stub to continue the the pipe on to the gate valve
  • Tabnero
    the leak starts at the top on the back side
  • Dalehelman
    Is this where it is leaking?
    1. Hash  T@B Fun
  • Tabnero
    yes that is where it starts. Removal of previous work left a stub out with odd cut through it and short, ugly,,,list goes on nature to it
  • Tabnero
    is there saving grace in the world of abs plastic pipe???
  • Tabnero
    that big rubber sealant is lower on the back side as well. thereby adding such joy to the task at hand
  • 4ncar
    I mean, I am not a fan of "caulk jobs," but in light of the alternative, can you try to caulk that joint that has failed?  I mean like JB weld permanent caulk!
    2018 320S Outback
  • Dalehelman
    I would just apply 2 or 3 layers of regular ABS cement to the joint. That should stop the leak and fuse the parts together.
    1. Hash  T@B Fun
  • Tabnero
    that picture was taken before I new it was leaking a bit, so then I added some sticky flex seal, and it failed. Now I have been taking all that off with some goo off. tomorrow trying some locktight. say a prayer and wish me luck..I really need some time out in the wilderness
  • Dalehelman
    Once it is good and clean I would use only ABS cement. It will actually melt and fuse itself to the joints. Other products will only stick to the surface and eventually work loose.
    1. Hash  T@B Fun
  • dragonsdofly
    dragonsdofly Member Posts: 1,927
    @Tabnero, DH, who has been doing commercial maintenance for nearly 50 years totally agrees with @Dalehelman.  Use ABS cement only, and if necessary, more than one application. Good luck.
  • Tabnero
    I had placed some ABS cement on the out side and it has remained. It appears to be 3 or 4 pin hole sized leaks. So I think I will add some more cement and see if that will stop the dribble
  • Tabnero
    Ok update here. The exterior applied ABS cement has solved the problem and the pipe joint is not leaking. However, I am not particularly trusting of glue jobs so I have assembled a travel repair kit. I found a toilet flange piece that fits inside the 3 inch pipe. It has rubber seal. So I bought 2 and cut a 4 inch section off and put seals on both ends. If the pipe on the tab gets bumped or rattled apart, I will cut off the pipe and insert this solution. Thanks eveyone.
  • dragonsdofly
    @Tabnero, bonus points for creativity AND preparedness!
  • ericnliz
    ericnliz Member Posts: 4,437
    Good outside the box thinkin' @Tabnero!
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
  • Dalehelman
    I like it. If you are prepared you’ll probably never need it.
    1. Hash  T@B Fun
