Battery Access for 2020 T@b 400
Jbreunig
Member Posts: 25
Where are the batteries and how do I access them on the 2020 T@b 400?
Under the bed?
Towed by 2014 Touareg TDi -
From what I have seen in various videos, the batteries are under the center section of the bed aft of the air conditioner and under a separate screw down panel.
Behind the center bed section. You’ll need to remove about 6 square head screws in order to lift off the panel to gain access to the batteries.
the 2020 tab 400 bd lite comes with twin Discover agm batteries. They seem to be a Canadian company. Anyone know anything about the quality of these batteries? Also, is the converter in the 400 a 4-stage? Thanks, Greg
Hi Greg, interesting that you should have Discover batteries, our's are Harris and these seem to do their job.The converter is theoretically a 3-stage converter, but because of its remote location and resistance of leads between it and the battery, it is effectively a 2-stage converter as it never uses "bulk" charging. Expect long recharge times.Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA
Can this problem be solved by installing a new 4-stage converter?
- 915 Tips & Tricks
