Keder Rail leaks ?
Tampakayaker
Member Posts: 558
We went on our first trip with our T@B over Veterans Day weekend.
We put up our visor that my wife had made and it fit great.
Overnight we had some heavy rain and the visor itself didn't leak (it was made from Sunbrella cloth).
What I did notice the next morning was some water seeping down the outer wall of the camper between the wall and the Keder rail.
Anyone else notice this happening?
Should I get the ladder out and run a bead of caulk along the top edge of the rail.
I don't want any rain to seep into the walls via the screws holding the rail on.
Tampa FL
Tampa FL
Good news is that it’s an easy fix! You need to seal the seams where the fabric attaches to the keder piece. Heavy rain will do that! I’ve got gorilla tape on my tarp awning now for the same problem in the same places and no leaks in heavy rain.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
@Tampakayaker, I had the same problem with water running behind the keder rail on my 2015 320. I backed out the screws and applied a small bead of sealant just below the top of the rail above the screws, snugged everything up, and no more leaks.Dennis and Mary Jo
North Carolina
2015 T@b Max Q -
What type of sealant did you use, and what color?norwood said:@Tampakayaker, I had the same problem with water running behind the keder rail on my 2015 320. I backed out the screws and applied a small bead of sealant just below the top of the rail above the screws, snugged everything up, and no more leaks.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Clear silicone caulk will do the job.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
Yep, clear silicone for this application.Dennis and Mary Jo
North Carolina
2015 T@b Max Q -
I thought silicone sealant was a no no on T@B's because it doesn't stick properly?norwood said:Yep, clear silicone for this application.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
NuCamp recommends polyurethane marine caulk
I’ve used silicone caulk on my prior 320 T@B without issues. This sealant is also used on smooth fiberglass fixtures such as bathroom fixtures, etc. And for this particular issue in sealing up a seam along the Keder rail, it shouldn’t pose any problem. Less is better and a wet finger or damp rag will work well so far as spreading the sealant and making cleanup easier.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
- 916 Introductions
- 72 Teardrop Groups & Links
