solar battery charge on 2020 boondock?
boonie
Member Posts: 83
if my tab is sitting in the driveway, no shore power, battery disconnect off, will the solar panel still trickle charge the battery? thanks
2018- 400- Colorado V6-Marin MT bikes
Yes. The solar charge controller is wired ahead of the battery disconnect switch. Same for the inverter, so it’s important the inverter switch is turned off when you are not using the camper. (If you have an inverter.)
- 915 Tips & Tricks
