Peel & stick tile for backsplash?
Anyone here put up the peel & stick tiles for a backsplash? Easy, hard or just tedious? How are they holding up, still sticking good? How warm do you think the inside of the trailer needs to be to apply them and let them cure? How many squares did you end up using? I have a 320S. Any advice is welcome--I'm thinking about doing this over my holiday break from work.
2018 Tab 400
  • GatorEgg
    GatorEgg Member Posts: 482
    Be careful attaching stick on attachments to the walls.  Previous owner had attached a couple of Command Strip hooks in our unit.  Using the hooks have separated the outer from inner coating.
    Odessa, Fl.
  • Tabnero
    Tabnero Member Posts: 253
    It is easy to do. I found Smart tile to be fun to use
  • Tabnero
    the smart tile apply and remove easily
