TAB 400 2021 ALDE Glycol Refill Location (Boondock)
Can someone tell me where the 2021 TAB 400 (Boondock) ALDE Glycol refill location is located? In the future it might be a good thing to know.
  • Tabfortwo
    Tabfortwo Member Posts: 157
    I believe it's in the drivers side porthole window
  • Giota
    Giota Member Posts: 57
    You are exactly right! Thank you for the Quick Response Tabfortwo!
  • ontheroad
    ontheroad Member Posts: 489
    @Giota...the search feature is amazing within this group..I don't even own our T@b 320 CS-S yet and I've learned where it is...   😁
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • ChrisFix
    ChrisFix Member Posts: 743
    @Giota
    And in case you haven't already figured this out, the panel covering the glycol canister is simply secured by 4 keyhole screws...Just slide the panel up about 1/4" and the panel can be pulled out over the screw heads.
  • Mags
    Mags Member Posts: 1
    Thank goodness for this forum. Would not have found the glycol tank without you all. And what a surprise to find it there and the hole in the panel for quick referencing. Thank you, @Giota.
