Help with replacing faucet
2020 T@B 320 Boondock
Factory Victron Solar, Norcold 3 way Fridge
Clueless about everything electronic
2020 Subaru Ascent
Bainbridge Island, Wa
You need a special tool, i just cut it off and used a screw type clamp to replace it2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut1
Although I have a 2018 400, your picture looks a lot like the Dometic faucet I broke when I replaced the original round bathroom 400 sink with the modified better draining, square one. The metal clamps are ½” Sharkbite stainless PEX clamps you can buy at HD or Lowes. You need a special tool to secure them. They also have a special tool to remove them however check out Youtube. Sharkbite tools are not cheap.
I removed the Sharkbite clamps with a bolt cutter but the supply lines seemed permanently “welded” to the plastic barbed outlet on the faucet. You might want to try a heat gun to soften the supply line where it is currently attached when you remove or reinsert it. It may make it easier. You can probably use any suitable clamp.
Good luck.
2018 T@B 400/solar/2022 Honda Ridgeline0 -
Thank you for your seasoned advice.Kr@cken
2020 Subaru Ascent
Bainbridge Island, Wa0 -
If the two stems are plastic, you may be able to use brute force & just break them off using a pair of vice grips or pliers to hold it, and maybe score them first with a small hack saw or file.-Brian in Chester, Virginia
I had the same issue today of not having a shark bite tool, so I just cut them with a hack saw blade and pulled the faucet off. The new faucet was easy to install.
2022 T@B 400 BD, the T@bacabana
TV: 2017 Chevy Tahoe1
