TV Antenna
GaryLee
Member Posts: 3
Would appreciate any recommendations on a simple, inexpensive TV antenna for a 2016 TAB S MAX. One that I can just hook up to the coaxial cable
connection without any special or additional mounting. Thank you.
We have used this antennae:
KING OA1501 OmniGo Portable Omnidirectional HDTV Over-the-Air Antenna - Black
2013 Tundra TRD 5.7L
Massachusetts -
See my post in this discussion, so simple you’ll laugh:
https://tab-rv.vanillacommunity.com/discussion/comment/144017#Comment_144017
This is the one we installed. We leave it attached and then extend as needed. Then it telescopes down when we travel.
Here's the link:
https://www.ebay.com/itm/F-Type-Telescopic-Aerial-Antenna-75-Ohm-with-TV-3-5-Adapter-Bose-Wave-Radio-FM/122461765807?_trkparms=aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20200520130048&meid=e366a8660dc94550ad02d140cb27f118&pid=100005&rk=1&rkt=12&mehot=co&sd=153301415060&itm=122461765807&pmt=1&noa=0&pg=2047675&algv=SimplAMLv5PairwiseWebWithDarwoV3BBEV2b&_trksid=p2047675.c100005.m18512014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota -
Some comments in a recent thread showed that the simplest antennas sometimes worked very well. The one posted above by Spruce1 is a perfect example.
Towed by 2014 Touareg TDi -
I had an extra one of these so I tried it and it works great in my driveway. I disconnected the plug in power cord to amplify it and picked up quite a few stations. If I was somewhere plugged into shore power, I suppose I'd plug it in.
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
